Hopp til produktinformasjon
1 av 4
AiM 22 Pin Deutsch Harness MXS, MXP, MXG, MXL2 Motorcycle
SKU: H22-V02573020-MC
£320.00
£320.00
The AiM 22 pin harness is an optional extra which is used to add extra channels and advanced functions to your kit.
Suitable for MXS, MXP, MXG, MXL2 Optional harness
 Digital output 22 pin harness
22 pin Optional Harness for the MX Series
The AiM 90° 22 pin harness plugs into the 22-pin connector on the MXS, MXP, MXG or MXL2 dash loggers.
Several of the advanced functions rely on this harness, which is not included with the standard 37 pin harness which comes as standard with the dash loggers.
The 22 pins optional harness provides access to the following functions:
Digital 12V outputs 1, 2
RS232 ECU connection
Please Note: The standard harness that comes with the MXS, MXG, MXP, and MXL2 allows 4 inputs. If you would like more inputs for your race data then add this optional harness to your kit.
  • 22 pin Deutsch Female Flying Connector
  • Table of none ended cables  - See table in Downloads Tab
  • 22 pin Harness for MXS, MXP, MXG, MXL2
