Yamaha YZF-R1/R1M & YZF-R6 AiM EVO4S Logger Plug & Play Cable
SKU: YAM-1-PP-EVO
- 정가
- £67.00
- 정가
- 세일 가격
- £67.00
- 단가
- 당
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to the EVO4S Data Logger. With a 7-pin 712 male binder connection.
Yamaha plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for EVO4S Data Logger |
Yamaha Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the EVO4S Data Logger.
Yamaha YZF-R1 - From 2015 | Yamaha YZF-R1M - From 2015 |
Yamaha YZF-R6 - From 2017 |
Example data protocols
- Below is a pinout drawing for the Yamaha YZF-R1/R1M & YZF-R6 EVO4S Data Logger plug & play connection cable
- Yamaha YZF-R1/R1M & YZF-R6 EVO4S Data Logger Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to the EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Yamaha bike models:Yamaha YZF-R1 - From 2015 | Yamaha YZF-R1M - From 2015 |
