Suzuki GSX-R AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SOLO2-K-SUZ-SM-CAM-GP-2-SM-GPC
- 정가
- £2,210.00
- 정가
- 세일 가격
- £2,210.00
- 단가
- 당
Suzuki GSX-R AiM Solo 2 DL + SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
The Suzuki plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide | Suzuki ECU connection cable |
This ultimate track day kit has been specifically designed for Suzuki bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Suzuki ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
GSX-R600 - 2006-2019 | GSX-R750 - 2006-2019 |
GSX-R1000 - 2005-2019 | GSX-R1300 Hayabusa Gen.2 - 2008-2016 |
The Solo 2 & Solo 2 DL installation brackets are available for the following bike models/years:
GSX-R600 - 2001-2019 | GSX-R750 - 2001-2019 |
GSX-R1000 - 2001-2004 and 2009-2019 |
Please Note: Not all product combinations are possible. Solo 2 DL installation brackets are not available for Suzuki GSX-R 1000 from 2005-2008, or GSX-R 1300 Hayabusa.2 from 2008-2016. Please contact one of the AiM support team for further information.
Powerful Combination
The Suzuki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
SmartyCam 3 GP
Automatic Start/Stop
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
- SmartyCam 3 GP
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
Below is the pinout drawing for the Suzuki plug & Play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- SmartyCam 3 GP - Bullet Cam
- External CAN cable 2m
- External power cable
- Suzuki Plug & Play connection cable
- 1 Bracket
- 1 toothed washer
- 1 rubber dowel
The Suzuki plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.Key Features :
This ultimate track day kit has been specifically designed for Suzuki bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Suzuki ECU will give you all the engine performance information you need to help improve your driving performance.SmartyCam 3 GP Features:
The plug & play cable currently fits the following Suzuki bike models:GSX-R600 - 2006-2019 | GSX-R750 - 2006-2019 |
The Suzuki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
SmartyCam 3 GP
- GPS: 10 Hz
- Memory: 4 GB
- SmartyCam 3 GP
- Video Out: 3G-SDI
- Solo 2 DL
- 1 Bracket
- 1 toothed washer
- 1 rubber dowel
