Suzuki GSX-R 1000/750/600 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-SUZ
- 정가
- £710.00
- 정가
- 세일 가격
- £710.00
- 단가
- 당
+ VAT(영국만 해당)
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Suzuki this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide | Suzuki ECU connection cable |
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Solo-2-DL-Display-Colours_240x240.gif?v=1613590480)
This kit has been specifically designed for Suzuki bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Suzuki ECU will give you all the engine performance information you need to help improve your driving performance.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Suzuki_Bike.png?v=1620394948)
GSX-R600 - 2006-2019 | GSX-R750 - 2006-2019 |
GSX-R1000 - 2005-2022 | GSX-R1300 Hayabusa Gen.2 - 2008-2016 |
The Solo 2 & Solo 2 DL installation brackets are available for the following bike models/years:
GSX-R600 - 2001-2019 | GSX-R750 - 2001-2019 |
GSX-R1000 - 2001-2004 and 2009-2019 |
Please Note: Not all product combinations are possible. Solo 2 DL installation brackets are not available for Suzuki GSX-R 1000 from 2005-2008, or GSX-R 1300 Hayabusa.2 from 2008-2016. Please contact one of the AiM support team for further information.
The Suzuki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Below is the pinout drawing for the Suzuki plug & play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- User manual
- AiM Suzuki Connection Cable
- Bracket
- 1 Allen screw with a rounded head M8 x 45mm
- 1 toothed washer
- 1 rubber dowel
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Suzuki this kit will ensure an improvement in your driving performance.Key Features :
This kit has been specifically designed for Suzuki bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Suzuki ECU will give you all the engine performance information you need to help improve your driving performance.Plug & Play
The plug & play cable currently fits the following Suzuki bike models:![](https://cdn.shopify.com/s/files/1/0214/9392/files/Suzuki_Bike.png?v=1620394948)
The Suzuki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Aim_Solo_2_DL_Wifi_Communication_With_PC.png?v=1614779557)
The Solo 2 DL has integrated Wi-Fi, so if you want to review your data in more depth simply transfer your data securely and quickly onto a laptop or computer up to 50m away without the need for connectors and cables. You can then import the data into the Race Studio 3 software.![](https://cdn.shopify.com/s/files/1/0214/9392/files/Yamaha_YZF-R1_2009_-_2014_AiM_Solo_2_DL_Plug_Play_Lap_Timer_Kit_54b3a036-e2b6-4d6e-9ab0-a7c03c0f64b0.png?v=1619781880)
These are some of the items that can be added to our Solo 2 DL for incrementing the performance and data acquired.![](https://cdn.shopify.com/s/files/1/0214/9392/files/Free_Download.png?v=1629297377)
- GPS: 10 Hz
- Memory: 4 GB
- Solo 2 DL
- User manual
- Bracket
- 1 toothed washer
- 1 rubber dowel
![Suzuki GSX-R 1000/750/600 AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/SuzukiGSX-R1000_750_600AiMSolo2DLPlug_PlayLapTimerKit_1445x.png?v=1619793198)
![Suzuki GSX-R 1000/750/600 AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/SuzukiGSX-R1000_750_600AiMSolo2DLPlug_PlayLapTimerKit3_1445x.png?v=1619793262)
![Suzuki GSX-R 1000/750/600 AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/Solo2DLRearView_withMagnets_2compressed_96f7461c-8fb1-45fb-8103-8ffce6285222_1445x.png?v=1641560441)
![Suzuki GSX-R 1000/750/600 AiM Solo 2 DL Plug & Play Lap Timer Kit - AimShop.com](http://www.aimshop.com/cdn/shop/products/Solo2DLBottomCompressed_abe9792f-1781-400c-9b75-16e3b7e89b01_1445x.jpg?v=1641891746)
