Super B Nomada 12V105AH Lithium Traction Battery
SKU: SB-E-105
- 정가
- £1,410.00
- 정가
- 세일 가격
- £1,410.00
- 단가
- 당
The Nomada 12V105Ah is a modular Lithium Iron Phosphate (LiFePO4) rechargeable battery with a rated capacity of 105 Ah. This new addition to our portfolio of lithium batteries has a compact and lightweight modular design which means you can easily scale up your energy system. The Nomada is mainly designed for use as a system battery and not as a stand-alone battery.
The Nomada 12V105Ah-LT variant, with an internal heater, allows charging in ambient
temperatures below 0°C. This model efficiently heats the Li-ion battery using its own energy.
Through a well-designed system setup, the battery can be heated without depleting its
charge. This eliminates the need for additional cables or heaters
Product Features
- Modular traction battery
- Lithium Iron Phosphate (LiFePO4): Safe Li-ion technology
- Integrated BMS (Battery Management System),
- BIB or BCI with disconnect device (relay) is required
- PC+ABS (UL94 V-0) flame-retardant battery casing
- Terminals for 2 x M8 bolts
- External fuse needed
- Wired communication interface: CANopen
- Easy CAN bus interconnection
- Battery monitoring and history storage
- Adaptive cell balancing
- Configurable in serial or parallel connection
- Independent temperature sensor for DNV type approved battery
- The optional LT model includes internal heating
Intended Use
The Nomada 12V105Ah Li-ion battery serves as an energy source of 12V in power systems for recreational vehicles, commercial vehicles, leisure boats, commercial vessels and stationary applications. Potential applications for this Li-ion battery include: off grid power supply, marine power supply, medium for (renewable) energy storage and (traction) battery for vehicles. Using it as a starter battery is not possible. Up to 4 batteries can be connected in series or in parallel to increase the total capacity up to 420Ah. When using more than 4 batteries in series or parallel always consult Super B.
PERFORMANCE
Low maintenance
Fast charging
Safest lithium technology
High discharge currents
High capacity
Low weight
High cycle count
Low self-discharge
NOMADA PARALLEL CONFIGURATION
NOMADA SERIES CONFIGURATION
CERTIFICATIONS
3 Year Warranty
A 3-year warranty offers the best peace of mind. It is the benefit of years of continuous engineering improvement and proven experience with all of our batteries in the harshest environments.
When it comes to powering your electric vehicle or marine craft, the Super B Nomada 12v105ah Lithium Traction Battery is a top-of-the-line choice. This high-performance battery is designed to provide long-lasting power and reliability, making it ideal for a wide range of applications.
One of the key features of the Super B Nomada 12v105ah Lithium Traction Battery is its impressive energy density. This means that it is able to store a large amount of energy in a relatively compact package, making it perfect for use in vehicles where space is at a premium. With a capacity of 105 amp-hours, this battery is capable of delivering the power needed to keep your vehicle running smoothly for extended periods of time.
In addition to its energy density, the Super B Nomada 12v105ah Lithium Traction Battery is also known for its high level of efficiency. Unlike traditional lead-acid batteries, lithium batteries are able to deliver power consistently over their entire discharge cycle, without suffering from the voltage drop-off that can occur with other types of batteries. This means that you can rely on your Super B Battery for any event you enter into.
Testimonials
"These batteries are a game-changer for living off grid and we know, from talking to our fellow cruisers, that we are not the only ones making this change to lithium. Super B are the best in the business. As we continue our journey round the world we feel safe in the knowledge these may be the last set of batteries we ever need to install." -Sailing Fair Isle ...More
"We have 8 lithium iron phosphate batteries (LiFePO4) at the core of our sailing yacht, a massive upgrade from the old lead-acid. The simplicity of installation, quality, and durability made this a no-brainer!" -Feel the Breeze ...More
ELECTRICAL SPECIFICATIONS
MECHANICAL SPECIFICATIONS
TEMPERATURE SPECIFICATIONS
COMPLIANCE SPECIFICATIONS
GENERAL SPECIFICATIONS
Available to download Here
The Nomada 12V105Ah is a modular Lithium Iron Phosphate (LiFePO4) rechargeable battery with a rated capacity of 105 Ah. This new addition to our portfolio of lithium batteries has a compact and lightweight modular design which means you can easily scale up your energy system. The Nomada is mainly designed for use as a system battery and not as a stand-alone battery.The Nomada 12V105Ah-LT variant, with an internal heater, allows charging in ambient temperatures below 0°C. This model efficiently heats the Li-ion battery using its own energy. Through a well-designed system setup, the battery can be heated without depleting its charge. This eliminates the need for additional cables or heaters
Product Features
Intended Use
The Nomada 12V105Ah Li-ion battery serves as an energy source of 12V in power systems for recreational vehicles, commercial vehicles, leisure boats, commercial vessels and stationary applications. Potential applications for this Li-ion battery include: off grid power supply, marine power supply, medium for (renewable) energy storage and (traction) battery for vehicles. Using it as a starter battery is not possible. Up to 4 batteries can be connected in series or in parallel to increase the total capacity up to 420Ah. When using more than 4 batteries in series or parallel always consult Super B.PERFORMANCE
Low maintenance
Fast charging
High capacity
Low weight
High cycle count
Low self-discharge
CERTIFICATIONS
3 Year Warranty
Testimonials
Specifications
Quickstart Guide
Mobile App
