Revotec Aluminium Hose Adaptor Motorcycle
SKU: REV-25-18-B
- 정가
- £20.00
- 정가
- 세일 가격
- £20.00
- 단가
- 당
The Revotec Aluminium Hose Adaptors are designed to insert into a water hose to provide a take-off for a water temperature gauge sender or fan controller.
Inserts into waterhose | Provides takeoff for water temperature sender |
Range of sizes & threads available | |
The Revotec Aluminium Hose Adaptors are designed to insert into a water hose to provide a take-off for a water temperature gauge sender or fan controller. A screw-in barbed take-off is available separately to convert to a T piece.
High-quality hose adaptor CNC machined from aluminium.
Available in different diameters and M10 x 1.0mm thread or 1/8 NPT thread with milled flat for sensor seal
The overall length of the adaptors is 75mm, with a tread section length of 25mm.
- Hose Adaptors available in the following sizes:
- 25mm
- 28mm
- 30mm
- 32mm
- 35mm
- 38mm
- 45mm
- In either M10 or 1/8NPT
- Overall length: 75mm
- Thread section length: 25mm
- Revotec Aluminium Hose Adaptor - Whichever chosen at checkout
The Revotec Aluminium Hose Adaptors are designed to insert into a water hose to provide a take-off for a water temperature gauge sender or fan controller.Key Features :
The Revotec Aluminium Hose Adaptors are designed to insert into a water hose to provide a take-off for a water temperature gauge sender or fan controller. A screw-in barbed take-off is available separately to convert to a T piece.High-quality hose adaptor CNC machined from aluminium.
- 25mm
- 28mm
- 30mm
- 32mm
- 35mm
- 38mm
- 45mm
