제품 정보로 건너뛰기
1 11
MyChron 6 GPS Lap Timer
SKU: MY6
정가
£420.00
정가
세일 가격
£420.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
mychron 6
The Aim MyChron 6 is our latest GPS lap timer for karting, combining 30 years of experience with cutting-edge technology. With 25 Hz GPS and sensor inputs, the MyChron 6 GPS Lap Timer offers precise lap timing and advanced data analysis for both amateur and professional racers.
USB Type-C Connection
RGB Shift Light & Alarm LEDs
Integrated 25 Hz GPS
1 Temperature Input
RPM Input
4 GB Memory
Wi-Fi & Bluetooth Connectivity
Integrated 6-Axis Inertial Platform
20 Hour Battery Life
2 CAN Connections
8 Configurable RGB Backlight Colours
Digital Output: Programmable High/Low Activation
Why Choose The MyChron 6 GPS Lap Timer
The MyChron 6 Lap Timer is the newest data acquisition device in our MyChron series. Expanding on the features of its predecessor, the MyChron 6 GPS Lap Timer is sure to revolutionise how drivers and teams monitor and analyse performance on the track.
Due to its highly accurate 25 Hz GPS tracking, larger screen to display delta times and comprehensive data logging capabilities, the MyChron 6 Lap Timer provides detailed performance analysis for both amateur and professional racers.
Advanced Display & LED System
The MyChron 6 features a wide 320x136 pixel graphical display, ensuring excellent readability, even in changing light conditions. With an incorporated light sensor, brightness and contrast are automatically adjusted to maintain ideal visibility in all lighting conditions. This larger display allows drivers to clearly monitor not only their best vs current sector times, but also their heart rate, all at a glance. The new page layout also includes delta bargraphs per sector time and delta time from the reference lap, helping drivers make real time adjustments to improve their lap performance.
With the MyChron 6, 5 RGB shift lights can be customised to display delta lap times or function as traditional shift indicators. The 2 RGB alarm LEDs provide real time engine monitoring of vehicle temperature, ensuring the kart operates within optimal parameters and preventing overheating or potential damage. The new dedicated pages layout also includes split times and overall delta time, giving drivers easy access to key performance metrics during the race. With the MyChron 6, everything is configurable to suit your needs.
mychron 6 dedicated pages
Experience seamless connectivity with the advanced Bluetooth module of MyChron 6. If you wish to measure your heart rate while racing, simply connect the heart rate monitor to your MyChron 6 via Bluetooth. Note: The MyChron 6 is compatible with the most common heart rate monitors on the market.
Bluetooth Icon
Accurate Lap Times
The MyChron 6 features an internal, high precision, 25 Hz four navigation satellite systems (GPS, GLONASS, BeiDou, Galileo) receiver and an internal database including information about the track. Simply switch on the device, and it automatically recognises the track and gets the information about the Starting Line Position and the Time Zone. The precision of the calculated Lap Times is 1/100 of a second.
The improved GPS allows you to analyse racing lines, cornering speeds and braking points through the free Race Studio 3 software. The device is also ready for future mobile app integration with iPhone and Android.
Bluetooth Icon
Wi-Fi Connectivity
Second CAN
The second CAN is dedicated to connect external modules requiring CAN communication protocols.
Bluetooth Icon
Dedicated Storage
The USB-C connector, in addition to allowing you to charge your logger, permits to store all your data in the optional massive 16 GB dedicated memory module.
Bluetooth Icon
3D Accelerations & Gyro
The 6-axis 50 Hz Inertial Measurement Unit (IMU) measures acceleration in the forward-backward, up-down and right-left directions and the angular velocity in the kart's pitch, roll and yaw directions. It then calculates and relays that information in real time to the MyChron 6 to control the engine and the behaviour of the chassis. This provides detailed insights into your kart's dynamics, including steering position analysis for understanding oversteer and understeer to help fine-tune your kart setup for optimal performance on the track.
Bluetooth Icon
20-Hour Battery
Thanks to the new large high-performance battery and low-consumption electronics with up to 20 hours of autonomy, MyChron 6 will be your reliable companion on the track without the need for recharging.
Bluetooth Icon
Analyse With Race Studio 3
With Race Studio 3, you can analyse all data recorded by the MyChron 6 Lap Timer and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performance.
Compatible Expansions
The MyChron 6 Lap Timer is compatible with various expansions and modules to enhance performance and expand on data collection. Compatible expansions include:
mychron 6
1 Temperature Input
RPM Input
4 GB Memory
2 CAN Connections
Bluetooth Icon
Accurate Lap Times
Bluetooth Icon
Wi-Fi Connectivity
Second CAN
Bluetooth Icon
Dedicated Storage
Bluetooth Icon
Bluetooth Icon
20-Hour Battery
Bluetooth Icon
MyChron 6
  • Display: Graphical
  • Wi-Fi connection: Yes
  • Bluetooth connection: Yes
  • GPS: 25HZ
  • External power: 29÷15 V
  • CAN connections: 2
  • Temperature inputs: 1
  • Memory: 4GB
  • Battery Life: 20 h approx.
  • Body: PA6 GS30%
  • Weight: 370g
  • Waterproof: IP67
What's In The Box
MyChron 6
  • MyChron 6 Lap Timer
  • RPM sensor
  • USB-C charger
