제품 정보로 건너뛰기
1 5
AiM MXP 1.3 6" TFT Motorcycle Display Dash Data Logger
SKU: MXP-CR4-XA6MXPA40R1
정가
£2,190.00
정가
세일 가격
£2,190.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
AiM MXP 6" TFT Display Dash Data Logger
The MXP dash logger has a 6" TFT display which has been designed to acquire and display data coming from the ECU.
6" TFT display GPS Module
CAN output 10 configurable RGB LEDs shift lights
Connecting the MXP dash to your ECU is simple. You can sample dozens of channels straight from the vehicles ECU. This is usually the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections and analogue sensors. The sampled data will depend on your actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air/fuel ratio). The list of available ECU drivers is constantly updated and upgraded and includes approximately 1000+ different  ECUs.
Two Digital Outputs
Flexible Alarms
CAN output
GPS Module
Pin Harness
  • Display: 6" TFT Display
  • CAN connections: 3
  • ECU connection: CAN, RS232 or K-Line to 1,000+ industry-leading ECUs
  • Second CAN: Yes
  • Wi-Fi connection: Yes
    + 3 axis magnetometer
  • Internal Memory: 4 GB
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400mA
  • Weight: 640g
  • MXP Dash Logger
  • 37 Pin standard harness
  • GPS Module with cable
Two Digital Outputs
Flexible Alarms
CAN output
GPS Module
Pin Harness
  • Second CAN: Yes
  • Weight: 640g
  • MXP Dash Logger
