Link Toyota JZXLink - JZX100X PlugIn ECU
SKU: TSJZX
- 정가
- £1,325.00
- 정가
- 세일 가격
- £1,325.00
- 단가
- 당
Designed for the 1JZ VVTi engine.
ECU includes an onboard 4 bar MAP sensor.
Suitable Applications:
JZX100 with 1JZ VVTi engine
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
Expansion Connector 1:
Gnd - Sensor Ground Only
An Volt 4
An Temp 2
+5V Out - Low Current +5V Supply
An Volt 5
DI 3
DI 4
Aux Inj 8
Expansion Connector 2:
An Temp 4
DI 1
DI 2
Aux Ign 4
Aux Ign 5
Aux Ign 6
An Volt 1
An Volt 2
- G4X PlugIn ECU
- Stickers
JZX100 with 1JZ VVTi engineG4X PlugIn Key Features (where applicable):
CAN port
Staged injection
An Volt 4
An Temp 2
An Volt 5
DI 3
DI 4
Aux Inj 8
An Temp 4
DI 1
DI 2
Aux Ign 4
Aux Ign 5
Aux Ign 6
An Volt 1
An Volt 2
- G4X PlugIn ECU
- Stickers
