Link Subaru WRXLink (3-4) WRX4X PlugIn ECU
SKU: WRX4X
- 정가
- £850.00
- 정가
- 세일 가격
- £850.00
- 단가
- 당
Designed for the WRX V3-4 EJ20
Air temp sensor highly recommended.
Suitable Applications:
GC8D
GC8E
WRX and STI from 09/1996 to 08/1998
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
XS connector 1
Gnd Sensor Ground Only
+5V Low Current +5V Supply
DI 5 Digital Input
DI 6 Digital Input
Volt 5 Analog 0-5V input
Volt 6 Analog 0-5V input
Temp 4 Temperature sensor input
Temp 3 Temperature sensor input
Expansion connector 2
DI 9 Digital Input
DI 10 Digital Input
Volt 8 Analog 0-5V input
Volt 9 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
GC8DGC8E
CAN port
Staged injection
XS connector 1Gnd Sensor Ground Only
DI 5 Digital Input
DI 6 Digital Input
DI 9 Digital Input
DI 10 Digital Input
- G4X PlugIn ECU
- Stickers
