Link Pressure Sensor 1/8"NPT (PS150)
SKU: PS150
- 정가
- £170.00
- 정가
- 세일 가격
- £170.00
- 단가
- 당
+ VAT(영국만 해당)
Link Pressure Sensor (PS150)
Link pressure sensor, suitable for use with either oil or fuel. 10 bar/150PSI, with NPT thread.
Oil or Fuel pressure
10 Bar/150psi
1/8” NPT Thread
Includes plug and pin kit
Up to 150 PSI above atmospheric pressure, cannot be used to read vacuum
0.5v = 0bar / 0PsiG
4.5v = 10 Bar / 145.03PsiG
- Pressure Sensor 150PSI 1/8" NPT
- Plug and pins
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Link_Banner_Description.png?v=1616071775)
Link pressure sensor, suitable for use with either oil or fuel. 10 bar/150PSI, with NPT thread.Oil or Fuel pressure
10 Bar/150psi
1/8” NPT Thread
![](https://dealers.linkecu.com/SSP%20Applications/NetSuite%20Inc.%20-%20SCA%202019.1/Development/img/Product%20Description%20Images/PS150.png)
0.5v = 0bar / 0PsiG
- Plug and pins
![Link Pressure Sensor 1/8"NPT (PS150) - AimShop.com](http://www.aimshop.com/cdn/shop/products/LinkPressureSensor1_8_NPT_PS150_1445x.png?v=1618217996)
![Link Pressure Sensor 1/8"NPT (PS150) - AimShop.com](http://www.aimshop.com/cdn/shop/products/LinkPressureSensor1_8_NPT_PS150_2_1445x.png?v=1618217998)
