Link Field Installable CAN Plug
SKU: CANF
- 정가
- £18.70
- 정가
£22.00 - 세일 가격
- £18.70
- 단가
- 당
Link Plug (CANF)
Required to add CAN/Serial communications to G4+/G4X Plugin ECU’s. Plugs directly into ECU PCB header. Use the Link CANF connector (purchased separately) to connect.
Link Plug (CANF)
Required to add CAN/Serial communications to G4+/G4X Plugin ECU’s. Plugs directly into ECU PCB header. Use the Link CANF connector (purchased separately) to connect.What's in The Box
- Field Installable CAN Plug
