Link Pin Kit "A" #TKA
SKU: TKA
- 정가
- £35.00
- 정가
- 세일 가격
- £35.00
- 단가
- 당
Pin Kit "A" All WireIn ECUs
Equivalent plug and connectors as "A" Loom. Plug and Pin Kit only.
Suitable for:
All Link G4X WireIn ECU’s (Note: Loom B/Pin Kit B will also be required for the Storm/Fury/Xtreme)
Link G4+ Atom (NB: Does NOT suit the earlier G4 Atom models. I.e. G4+ only)
Link G4+ Atom II
Link G4+ Monsoon
Link G4 Storm
Link G4+ Storm Blue
Link G4+ Storm Black (Note: Loom B/Pin Kit B will also be required)
Link G4 RX
Link G4+ Fury (Note: Loom B/Pin Kit B will also be required)
Link G4 Xtreme (Note: Loom B/Pin Kit B will also be required)
Link G4+ Xtreme (Note: Loom B/Pin Kit B will also be required)
Link G4+ Thunder (Note: Loom B/Pin Kit B and connector kits C and D may also be required)
Vipec V44
Vipec i44
Vipec V88 (Note: Loom B/Pin Kit B will also be required)
Vipec i88 (Note: Loom B/Pin Kit B will also be required)
- Plug & Pins - Pin Kit "A"
Pin Kit "A" All WireIn ECUsEquivalent plug and connectors as "A" Loom. Plug and Pin Kit only.
Suitable for:
All Link G4X WireIn ECU’s (Note: Loom B/Pin Kit B will also be required for the Storm/Fury/Xtreme)Link G4+ Atom (NB: Does NOT suit the earlier G4 Atom models. I.e. G4+ only)
Link G4+ Atom II
Link G4+ Monsoon
Link G4 Storm
Link G4+ Storm Blue
Link G4 RX
Vipec V44
Vipec i44
