제품 정보로 건너뛰기
1 2
Link Nissan S15Link - #NS15X PlugIn ECU
SKU: NS15X
정가
£1,325.00
정가
세일 가격
£1,325.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
Designed for the SR20 engine. This ECU will work with the 64 pins, blue header plug ECU version.
ECU includes an onboard 4 bar MAP or 7 bar MAP sensor.
Suitable Applications:
S13 Silvia / 180SX SR20DET (but not CA18DET)
S14a Silvia (facelift) SR20DET
S15 Silvia SR20DET
S15 Silvia SR20DE
RNN14 Pulsar GTI-R SR20DET
N15 Pulsar SR16VE
N14 Distributed
*For the 76 pin header ECU, have a look at the S13X PlugIn listing.
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
DI6 Digital Input
DI7 Digital Input
An Volt 5 Analog 0-5V input
An Volt 6 Analog 0-5V input
Expansion connector 2
Ign 5 Ignition 5 Auxiliary output
Ign 6 Ignition 6 Auxiliary output
Ign 7 Ignition 7 Auxiliary output
DI 8 Digital Input
Volt 8 Analog 0-5V input
Volt 9 Analog 0-5V input
Volt 10 Analog 0-5V input
Volt 11 Analog 0-5V input
  • G4X PlugIn ECU
  • Stickers
S15 Silvia SR20DET
S15 Silvia SR20DE
N15 Pulsar SR16VE
N14 Distributed
CAN port
Staged injection
DI6 Digital Input
DI7 Digital Input
DI 8 Digital Input
  • G4X PlugIn ECU
  • Stickers
