Link "B" Loom Short - #OLB
SKU: OLB
- 정가
- £67.00
- 정가
- 세일 가격
- £67.00
- 단가
- 당
Link A Loom Short 0.4m - #OLA
Loom "B" 400mm - All WireIn ECUs, not required for Atom
0.4m long 'B' loom to suit G4, G4+ and G4X Wire-In ECUs
Perfect for all custom wiring jobs utilising Link WireIn ECUs. The ‘B’ Loom has a Link ‘B’ ECU connector at one end and unterminated wires at the other. All wires are colour coded to match the manual. This loom is also available in 2.5m and 5m lengths.
Suitable Applications:
Link G4X Storm (Loom A also required)
Link G4X and G4+ Fury (Loom A also required)
Link G4X, G4+ and G4 Xtreme (Loom A also required)
Link G4+ Thunder (Note: Loom A and connector kits C and D may also be required)
Link G4+ Storm Black (Loom A also required) – Note: Loom B is not required for the older Silver or Blue G4 or G4+ Storm models
Vipec V88 (Loom A also required)
Vipec i88 (Loom A also required)
- "B" Loom Short 0.4m
Loom "B" 400mm - All WireIn ECUs, not required for Atom0.4m long 'B' loom to suit G4, G4+ and G4X Wire-In ECUs
Link G4X Storm (Loom A also required)Link G4X and G4+ Fury (Loom A also required)
