Honda CBR 600RR, CBR 1000RR AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: HON-PP-HON-B
- 정가
- £85.00
- 정가
- 세일 가격
- £85.00
- 단가
- 당
Honda 600CBR, 1000CBR AiM Solo 2 DL Motorcycle Cable & Bracket
The AiM Honda motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Honda cable & bracket | 7 pin - 712 male binder connection |
Honda Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Honda bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Honda bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Please Note: The bracket is only compatible with CBR 600RR original triple clamp.
CBR 600RR - 2003-2019 | CBR 600RR HRC with D11 marked ECU - 2013-2015 |
CBR 1000RR - 2004-2016 | CBR 1000RR HRC - 2014-2016 |
Example data protocols
- Specifically designed Honda Plug & play cable and bracket for the Solo 2 DL
- Below is the pinout drawing for the Honda plug & play connection cable.
- Honda plug & play connection cable
- 1 bracket
- 1 washer
- 1 Allen screw with rounded head M6 x 60
- 1 rubber dowel
The AiM Honda motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Honda bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.The AiM Honda bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following Honda bike models:CBR 600RR - 2003-2019 | CBR 600RR HRC with D11 marked ECU - 2013-2015 |
- 1 bracket
- 1 washer
- 1 rubber dowel
