Ducati Panigale V4/V2 AiM Solo 2 DL Plug & Play Cable
SKU: DUC-PP
- 정가
- £67.00
- 정가
- 세일 가격
- £67.00
- 단가
- 당
+ VAT(영국만 해당)
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale V4/V2 bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Ducati Panigale V4/V2 plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL |
Ducati Panigale V4/V2 Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale V4/V2 bike. This plug & play cable can be used for the Solo 2 DL.
The plug & play cable currently fits the following Ducati Panigale bike models:
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Ducati_V4-V2_Bike.png?v=1620661272)
Panigale V4 - From 2018 | Panigale V2 - From 2020 |
Example data protocols
- Below is a pinout drawing for the Ducati Panigale V4/V2 plug & play connection cable
- Ducati Panigale V4/V2 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale V4/V2 bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale V4/V2 bike. This plug & play cable can be used for the Solo 2 DL.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Ducati Panigale bike models:![](https://cdn.shopify.com/s/files/1/0214/9392/files/Ducati_V4-V2_Bike.png?v=1620661272)
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
![Ducati Panigale V4/V2 AiM Solo 2 DL Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/DucatiPanigaleV4_V2AiMSolo2DLPlug_PlayCablenew_1445x.png?v=1620811149)
![Ducati Panigale V4/V2 AiM Solo 2 DL Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/DucatiPanigaleV4_V2AiMSolo2DLPlug_PlayCable2_1445x.png?v=1620811149)
