제품 정보로 건너뛰기
1 2
Ducati Hypermotard 796 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: DUC-PP
정가
£67.00
정가
세일 가격
£67.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
Ducati Hypermotard 796 AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Hypermotard bike. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati Hypermotard plug & play cable 7 pin - 712 male binder connection
Ducati Hypermotard Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Hypermotard bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
The plug & play cable currently fits the following Ducati Hypermotard bike model:
Hypermotard 796 - 2009-2011
Example data protocols
  • Below is a pinout drawing for the Ducati Hypermotard plug & play connection cable
  • Ducati Hypermotard Plug & Play connection cable
