Deutsch Male & Female DT Plug & Pins including Wedge Lock
SKU: P-DT-2-F
- 정가
- £2.00
- 정가
- 세일 가격
- £2.00
- 단가
- 당
The Deutsch Male & Female DT Plug & Pins, including wedge lock, are designed for cable to cable connection. The seals provide a robust seal with a high degree of environmental protection.
Male & Female DT plugs | Pins & wedge lock |
2 to 12 way options | |
Safe, versatile and reliable, the DT plug connector housings are made from thermoplastic, ideal for automotive applications.
The plug & pins are suited for applications that require a secure & reliable connector in harsh environments, like under the hood of your car, transmission tunnels and other areas that need secure connections in both power and signal.
- Tactile and audible connector mating
- Rugged thermoplastic connector housing
- Hand insertable/removable connects
- Operating temperature range: -55 to +125°C
- Positive contact retention
- 1 x DT Deutsch plug, pins, wedge lock
The Deutsch Male & Female DT Plug & Pins, including wedge lock, are designed for cable to cable connection. The seals provide a robust seal with a high degree of environmental protection.Key Features :
The Deutsch Male & Female DT Plug & Pins, including wedge lock, are designed for cable to cable connection. The seals provide a robust seal with a high degree of environmental protection.Safe, versatile and reliable, the DT plug connector housings are made from thermoplastic, ideal for automotive applications.
