BMW S1000RR AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: BMW-B
- 정가
- £60.00
- 정가
- 세일 가격
- £60.00
- 단가
- 당
The AiM BMW motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
BMW bracket | All necessary mounting hardware |
Suitable for Solo 2 & Solo 2 DL | |
BMW Solo 2 & Solo 2 DL Bracket
The BMW S1000RR bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Nole: If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Also available is our BMW plug & play cable for the following bike models: (Sold Separately)
S1000RR - 2009-2014 | S1000RR - From 2015 |
S1000RR HP4 - 2013-2014 |
Example data protocols
- Specifically designed BMW S1000RR bracket for the Solo 2 and Solo 2 DL
- 1 Bracket
- 1 toothed washer
- 1 rubber dowel
- 1 spacer
The AiM BMW motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
The BMW S1000RR bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.Our brackets are supplied with all the necessary hardware required for fitting to your bike.
Also available is our BMW plug & play cable for the following bike models: (Sold Separately)S1000RR - 2009-2014 | S1000RR - From 2015 |
- 1 Bracket
- 1 toothed washer
- 1 rubber dowel
- 1 spacer
