제품 정보로 건너뛰기
1 1
Aprilia RSV4 AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: APR-B
정가
£42.00
정가
세일 가격
£42.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
The AiM Aprilia motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Aprilia bracket All necessary mounting hardware
Suitable for Solo 2 & Solo 2 DL
Please Note: The bracket is only compatible with RSV4 original triple clamp.
Also available is our Aprilia plug & play cable for the following bike models: (Sold Separately)
Aim Aprilia Motorcycle
Aprilia RSV4 RR/RF - From 2017 Aprilia RSV4 1100 - From 2019
Aprilia Tuono V4 RR/Factory - From 2017
Example data protocols
  • Specifically designed Aprilia RSV4 bracket for the Solo 2 and Solo 2 DL
  • 1 Bracket
  • 1 toothed washer
  • 1 rubber dowel
  • 1 Bracket
  • 1 toothed washer
  • 1 rubber dowel
