제품 정보로 건너뛰기
1 9
AiM Yarara Yamaha ATV ECU Plug & Play
SKU: Y-ECU
정가
£480.00
정가
세일 가격
£480.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
AiM Yarara Yamaha ATV ECU Plug & Play Engine Control Unit
Yarara is the plug & play ECU developed by AiM for being installed on the Yamaha YFZ450R. Thanks to its high technology 32-bit core, it is a good help for improving the performances of your ATV, without sacrificing reliability and smoothness.
Yarara is specifically designed for:
Yamaha YFZ450R Model year 2021 and 2022
Yarara Key Features & Advanced Strategies
Injection main  Injector 2 percentage
Injection user compensation Injector 2 phase
Injection main speed density Injector opening transient correction
Injection crank correction
Injector closing transient correction
Pre-injection Ignition main
Injection BAP correction Ignition user compensation
Injection EWT correction Ignition BAP correction
Inection IAT correction Ignition EWT correction
Injector 1 battery correction Ignition IAT correction
Injector 1 phase Ignition opening transient correction
Injector 2 battery correction Ignition close transient correction
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Yarara ECU guarantees the precision of 1/10 of the degree: this means an accuracy within 0.8 uses for turning the spark ON!
Tuner License :
This is the Tuner that is required to configure the unprogrammed Yarara ECU.
With this license, the tuner can create different maps, configurations and strategies. The tuner can then flash them directly onto the ECU or send them via email to allow the rider to download and install them in the ECU.
The Aim Handlebar Switch is the best way for changing the behaviour of your UTV; it features 2 pushbuttons, 10 LEDs and manages the following settings :
Below shows a functional diagram of products that can be added to the Yarara ECU:
AiM Yarara ECU Plug & Play Engine Control Unit
  • One low side driver (1 A)
  • Power consumption 150 mA
  • Connectors:
  • n.1 JAE male 18 pin MX23A18NF1 Connector
  • n.1 34 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Dimensions: 141.5x84.3x26.9 mm
  • Waterproof: IP67
  • Weight: 370g
  • ECU Yarara Control Unit
Tuner License :
  • Connectors:
  • Waterproof: IP67
  • Weight: 370g
Video
