AiM Car Steering Angle Rotary Potentiometer/ Belt Type Sensor
SKU: S-SA-X05SNST10G
- 정가
- £95.00
- 정가
- 세일 가격
- £95.00
- 단가
- 당
The AiM Steering angle (rotary potentiometer) sensor comes with a male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.
Measures the angle of a steering wheel | Supplied with mounting a bracket |
719 4 pin male connector | 10 Revolutions |
The steering angle sensor measures the angle of the steering wheel in degrees and is used to highlight over/under steering situations. It can pick out and see if the driver is losing time due to the steering input.
The sensor measures the angle of the steering wheel in degrees as the driver turns the wheel.
As the wheel is turned, you can see how much steering input has been put in. You can then pick out and see if the driver is losing time due to steering. This could be due to turning too much or too little into a corner.
MXS / MXP / MXG / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719 - 719 patch lead, which is available in various lengths from 0.5 - 3 metres.
For most installations, you will need one of these leads.
- Nominal Resistance: 10K ohm
- Tolerance on Resistance Value: 5%
- Precision: 0.030%
- Mechanical Displacement: 3600°
- Working Temperature Range: -55/+125°C
- Cable Length: 30cm
- 10G Steering Potentiometer
- 1 Toothed Belt
- 2 Toothed Pulleys
- 1 Allen Key
- 1 Bracket Kit
The AiM Steering angle (rotary potentiometer) sensor comes with a male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.Key Features :
The AiM Steering angle (rotary potentiometer) sensor comes with a male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.The steering angle sensor measures the angle of the steering wheel in degrees and is used to highlight over/under steering situations. It can pick out and see if the driver is losing time due to the steering input.
MXS / MXP / MXG / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719 - 719 patch lead, which is available in various lengths from 0.5 - 3 metres.For most installations, you will need one of these leads.
- Precision: 0.030%
- 1 Toothed Belt
- 2 Toothed Pulleys
- 1 Allen Key
- 1 Bracket Kit
