AiM Solo External Power Lead 3 Pin Unterminated
SKU: SOLO-EX
- 정가
- £42.00
- 정가
- 세일 가격
- £42.00
- 단가
- 당
The AiM external power lead fits the AiM Solo GPS Lap Timer.
3 pin - 712 male binder connection | Unterminated end with 2 wires |
Suitable for Solo 2 & Solo 2 DL | |
External Power Cable
The AiM external power cable fits the AiM Solo GPS Lap Timer. It features a 3-pin 712 male binder connection, which goes into the Solo GPS Lap Timer.
The un-terminated wires allow you to connect to an external battery.
This allows Solo GPS Lap Timer to have longer running times.
Please Note: This cable is for the older model Solo GPS Lap Timer.
- 3 pin - 712 male binder connection
- Unterminated end with 2 wires: 12V+ & Ground
- 2m length cable
- Solo External Power Lead 3 pin
The AiM external power lead fits the AiM Solo GPS Lap Timer.Key Features :
The AiM external power cable fits the AiM Solo GPS Lap Timer. It features a 3-pin 712 male binder connection, which goes into the Solo GPS Lap Timer.The un-terminated wires allow you to connect to an external battery.
- 2m length cable
