AiM Solo 2 Motocross / MX / Enduro GPS Lap Timer
SKU: SOLO2-K1-MX
- 정가
- £350.00
- 정가
- 세일 가격
- £350.00
- 단가
- 당
+ VAT(영국만 해당)
Integrated GPS
Wi-fi connectability
4GB Internal Memory
Database with over 4000 Tracks worldwide
Automatic Track Recognition
Ten configurable RGB LEDs
Graphical Display
Open or Closed track creation
Multiple Race modes: Speed, Times & Performance
Suitable for any motorsport vehicle
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Aim_Solo-2-GPS-Display_1fc9c5cd-8d7b-4ebb-9cfa-c806520df503_240x240.gif?v=1613599015)
The Most Precise and Easy Way to Get Lap Times
The AiM Solo 2 is the perfect Motocross, MX & Enduro GPS Lap Timer. It receives data from two satellite constellations: GPS and Glonass, giving you a significant improvement in data speed and positioning precision. This reduces start-up times to seconds and lap times are accurate to a tolerance of an impressive two-hundredths of a second.
Solo 2 Motocross GPS Lap Timer gives instant speed, timing splits live data and predictive lap times and it's high contrast display helps riders easily identify the data displayed on the screen at any speed.
The Solo 2 also features a selection of 7 different backlight colours, which you can select to suit your own personal requirements.
THE PERFECT MOTOCROSS MX ENDURO LAPTIMER
Can Be Fitted to your Motocross, MX, Enduro Bike with our optional Bar Pad.
Predictive Motocross Lap Timer
Predictive lap time is much more reliable on the Solo 2 Motocross GPS Lap Timer and the configurable RGB LEDs will give you a clear and fast indication of the comparison with your best lap.
Clear Racing Data Recall On Screen
Solo 2 can be used for circuit racing or point to point including performance tests. As with the circuit racing mode all data is recorded and can be reviewed immediately after each race or test session and of course can be downloaded to laptop trackside.
Solo 2 New Track Creation And Database
Solo 2 allows you to create a new temporary or permanent track layout. Whether it's a point to point run for rallying or a closed-loop track and if there is no track already, Solo 2 will create one for you.
Over 4000 Pre-loaded tracks from around the world, as soon as it's switched on the Solo 2 identifies its position. Once you start to drive, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you go past.
Wi-Fi Communication With The PC
The Solo 2 has integrated Wi-Fi to enable you to conveniently transfer your data securely, straight from your bike to you laptop trackside. You can then review your racing data in more depth, by importing into our powerful Race Studio 3 software which comes free with the Solo 2 Motocross. This can be done from up to 50m away without the need for connectors and cables and the data can then be imported into the Race Studio 3 software.
Configure & Analyse Solo 2 Motocross
with Our Free Race Studio 3 Racing Data Software
Race Studio 3 allows you to create, modify, delete, import and export race configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need.
Race Studio 3 Data Analysis Software can also analyse all data recorded by Solo 2 and download performance data to your Laptop/PC Trackside. You can view graphs, histograms and tables to aid and study race techniques, which will ultimately provide objective support to avoid mistakes and improve overall performance.
AiM Solo 2 GPS Motocross Lap Timer
- Display: Graphical
- Display Pages: Up to 5 freely configurable
- GPS: 10 Hz
- External power: 12 V
- Connectors : 1 socket (binder) 712, 5 pins
- Memory: 4 GB
- Solo 2 power cable with car lighter socket
- Power cable with AC adapter
Integrated GPS
4GB Internal Memory
Graphical Display
![](https://cdn.shopify.com/s/files/1/0214/9392/files/WiFi_Communication_With_The_PC_AiM_Solo_2.png?v=1614767340)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Free_Download.png?v=1629297377)
Technical Specifications
- GPS: 10 Hz
- Memory: 4 GB
![AiM Solo 2 GPS Offroad Lap Timer - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMSolo2GPSMotocrossLapTimer_1453ebfc-9015-4ae6-91f0-b674fd9002bf_1445x.png?v=1617008704)
![AiM Solo 2 GPS Offroad Lap Timer - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMSolo2GPSMotocrossLapTimer2_1445x.png?v=1617008704)
![AiM Solo 2 GPS Offroad Lap Timer - AimShop.com](http://www.aimshop.com/cdn/shop/products/Solo2RearView_withMagnets_compressed_95404a0c-3b04-4940-8fed-e5b3b74872d8_1445x.jpg?v=1641568120)
![AiM Solo 2 GPS Offroad Lap Timer - AimShop.com](http://www.aimshop.com/cdn/shop/products/Solo2BottomCompressed_762031b9-66e1-4a62-8fca-523d6506933c_1445x.jpg?v=1641891907)
