제품 정보로 건너뛰기
1 4
AiM Solo 2 DL OBDII & External Power Connector Cable Motocross
SKU: SOLO-K2-L
정가
£42.00
정가
세일 가격
£42.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
The AiM OBDII 2m external power cable connects your Solo 2 DL to your ECU wiring.
7 pin - 712 male binder connection OBDII connector
Suitable for Solo 2 DL
OBDII External Power Cable
The AiM OBDII 2m external power cable is used to make your AiM device, Solo 2 DL communicate with the vehicle ECU.
This is one of the connection cables available for the Solo 2 DL. Others are the RS232/CAN and the RPM cable.
Some of the OBDII protocol channels received are RPM, Vehicle speed, Fuel level, Throttle position. For an extended list of protocols please see the technical data sheet in the Downloads Tab.
  • 7 pin - 712 male binder connection
  • 2m Cable
  • OBDII Connector Pin:
  • 2 - Positive bus line - SAE J1850 protocol: not supported by AiM devices
  • 4 - Chassis GND
  • 5 - GND signal
  • 6 - CAN High - ISO 15765-4 and SAE J2234 protocols
  • 7 -  K-Line - ISO 9141-2 and ISO 14230-4 protocols
  • 10 - Negative bus line - SAE J18050 protocol: not supported by AiM devices
  • 14 - CAN low - ISO 15765 and SAE J2234 protocols
  • 15 - L line - ISO 9141-2 and ISO 14230-4 protocols
  • 16 - Battery supply
  • Solo 2 DL OBDII & External power cable connector
  • 2m Cable
  • 4 - Chassis GND
  • 5 - GND signal
