AiM SmartyCam 3 Bullet Camera Replacement Motocross
SKU: SM3-BC
- 정가
- £310.00
- 정가
- 세일 가격
- £310.00
- 단가
- 당
The AiM SmartyCam 3 replacement Bullet Camera, is a lightweight, robust replacement or spare part for your camera kit.
High-quality camera | Replacement for SmartyCam 3 |
Compact & robust | Lens options 67°, 87°, 120° |
Replacement Bullet Camera
The AiM replacement bullet camera has been designed for motorsport and is incredibly light and robust.
The bullet camera is black anodised, billet machined small and compact enough to fit into the tightest of locations.
Ideal to have one spare at the track in case your camera gets damaged.
If you have multiple vehicles you can have the correct lens for each specific vehicle.
Provides high-quality footage.
Lens Options
The replacement bullet camera is available in three lens versions.
The 67° lens is preferred for closed-roof cars, as it sees the track just within the windscreen pillars.
The 87° lens is available for open roof and formula cars where it is possible to have a more ample view of the track.
The 120° lens gives an even wider view of the track and surroundings.
Please Note: This replacement Bullet Camera is for the SmartyCam 3.
We also have Bullet replacement front glass kits available in three different lens applications.
These are some of the items that can be added to your vehicle for incrementing performance and data.
- Anodised black
- Billet machined
- Available in 67°, 87°, 120° lens
- 1 x Replacement Bullet Camera
- Lens option available 67°, 87°, 120°
The AiM SmartyCam 3 replacement Bullet Camera, is a lightweight, robust replacement or spare part for your camera kit.Key Features :
The AiM replacement bullet camera has been designed for motorsport and is incredibly light and robust.The bullet camera is black anodised, billet machined small and compact enough to fit into the tightest of locations.
Lens Options
The replacement bullet camera is available in three lens versions.The 67° lens is preferred for closed-roof cars, as it sees the track just within the windscreen pillars.
These are some of the items that can be added to your vehicle for incrementing performance and data.Technical
- Anodised black
- Billet machined
