AiM Remote Input / Output Module
SKU: I-O-Module
- 정가
- £125.00
- 정가
- 세일 가격
- £125.00
- 단가
- 당
The RIO02 Remote Input/Output Module is dedicated to pushbutton management when the available inputs are not enough.
Key Features:
The RIO02 Remote Input / Output Module is dedicated to push button management when the available inputs are not enough. It features 19 inputs, primarily dedicated to push button management. Easily configure momentary, two-position, and multi-status, with momentary controls for long and short push. It has 2 Low side, max 2A, digital outputs as well. |
Unlock your potential |
- CAN Connections
- Inputs: 19 of which - 8 prog: switch to Batt, Switch to ground, 11 Switch to Ground
- Dig Outs: 2 Low Side 2 A Max
- Body: Plastic
- Connectors: 1 AMP 776087-1 connector
- Weight: 129g
Key Features:
- CAN Connections
- Body: Plastic
- Weight: 129g
Whats In The Box
