제품 정보로 건너뛰기
1 1
Motorcycle Potentiometer Replacement Rose End Fitting
SKU: CASUS-POT-END-RJ-MC
정가
£8.50
정가
세일 가격
£8.50
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
AiM Potentiometer Replacement Rose End Fitting
Replacement rose end joint fitting for the suspension potentiometer.
Replacement rose end fitting Spare or replacement parts
The Potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.
Use as a replacement or spare part.
One Potentiometer Rose End Fitting Replacement Supplied.
  • Replacement Potentiometer Rose End Fitting
  • 1 x Rose End Fitting Potentiometer Replacement Fitting
