AiM Oil / Fuel Pressure Sensor M10 0-5 Bar Motorcycle
SKU: S-P-F-M10-MC
- 정가
- £190.00
- 정가
- 세일 가격
- £190.00
- 단가
- 당
+ VAT(영국만 해당)
The AiM M10 pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.
M10 - 0-5 bars | 4 pins 719 male binder |
The M10 0-5 bar pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.
The M10 - 0-5 bar pressure sensor is fitted with a male four pins 719 binder connector to suit our loggers and dash display/loggers.
This sensor is also available in a 0-5 Bar 3/8 24. Available in the accessories tab.
- Supply: 8-16V
- Consumption: < 10 mA
- Sealing: IP66
- Weight: 30g
- Cable Length: 400mm
- Thread: M10
- AiM M10 0-5bar pressure sensor
The AiM M10 pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.Key Features :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_Oil_Fuel_Pressure_Sensor_M10_0-5_Bar_main_description.png?v=1617798310)
The M10 0-5 bar pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.The M10 - 0-5 bar pressure sensor is fitted with a male four pins 719 binder connector to suit our loggers and dash display/loggers.
MXS, MXG, MXP, MXL (Strada & Pista), MXL2, EVO5, MXm harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, you will require our 719-719 patch lead available in various sizes from 0.5m - 4 meters in length. For most installations, you will need one of these patch leads.EVO4, EVO4S Data Logger, Channel Expansion are fitted with 712 connections and require a 712-719 patch lead to connect the sensor. This patch lead is available in 0.5m - 4-meter lengths. Patch leads are available in the optional extras.
- Supply: 8-16V
- Sealing: IP66
- Weight: 30g
- Thread: M10
![AiM Oil / Fuel Pressure Sensor M10 0-5 Bar Motorcycle - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMOil_FuelPressureSensorM100-5Bar_d0684296-2b54-478c-aed3-ce585fca6725_1445x.png?v=1617783804)
![AiM Oil / Fuel Pressure Sensor M10 0-5 Bar Motorcycle - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMOil_FuelPressureSensorM100-5Bar_827ad3f6-fb80-4351-822d-518f8df47b9e_1445x.png?v=1617783804)
![AiM Oil / Fuel Pressure Sensor M10 0-5 Bar Motorcycle - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMOil_FuelPressureSensorM100-5Bar2_f68ed888-3c2d-45c2-83ef-e831cbe922bf_1445x.png?v=1617783804)
![AiM Oil / Fuel Pressure Sensor M10 0-5 Bar Motorcycle - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMOil_FuelPressureSensorM100-5Bar3_8ff1199b-b2ed-4f77-875a-59f3437b774a_1445x.png?v=1617783804)
