AiM MXT 1.3 10" TFT Digital Display and Data Logger
SKU: MXT
- 정가
- £2,500.00
- 정가
- 세일 가격
- £2,500.00
- 단가
- 당
AiM MXT 1.3 10" TFT Dash Display and data logger
The MXT 1.3 features a 10" wide colour dash display offering great visual impact, and configurable to show data coming from your vehicles ECU.
10" TFT display | 6 alarm RGB LEDs |
CAN output | Configure data |
The MXT 1.3 has an integrated shift array, configurable multicolor alarms, drag and drop multi page configuration, Wi-Fi and USB connectivity, GPS09 Module, analog and digital inputs, digital outputs, Motorsport connectors, 4 GB of internal memory, 1,000Hz per channel sampling and support for over 1,000 ECU connections.
MXT 1.3 samples data coming from your ECU, the GPS09 Module, 8 fully configurable analog inputs, 6 digital inputs, predefined math channels and second CAN. Performance and data acquired can also be incremented adding up to eight expansion modules.
Freely configurable pages
You can define up to 8 custom pages, choosing among a selection of page styles, defining which data to be shown, their end of scale and measure units. Swapping between pages can be managed pushing one or two pushbuttons.
A high contrast TFT display identifies MXT 1.3 at the first glance. An ambient light sensor keeps the backlight at optimum brightness levels.
Flexible alarms & custom street icons
MXT 1.3 features five configurable RGB alarm LEDs: you choose the conditions, you choose the colors. Select a solid alarm or flashing one - and the flashing frequency, choose to have an accompanying text message, and set the alarm priorities. Furthermore you can select the street icons you need among the wide list you will find in "Race Studio 3 - Icons Management" and set them up the way you prefer or according with your needs. Any of them is fully configurable and if this shouldn't be enough, you will be able to upload and set up your own customized icons.
Two digital outputs
MXT 1.3 features two digital outputs. The two digital outputs (Dout) are LOW SIDE type (switch to ground): they can be configured in order to be turned on/off depending on the value of the analog or digital inputs. They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc. when a certain event happens.
Two analog camera inputs are available, to swap your display into a mirror camera, through pushbutton command or event management.
Integrated shift light array
Choose from a host of advanced multicoloured RGB shift light patterns that can be customized as you like, and for each unique gear when required.
Using the built-in CAN bus, you can add expansion modules to the MXT 1.3 to increment the performance and the data acquired:
GPS09 ModuleThanks to GPS09 Module (included in the kit) and its Race Studio 3 software, you can immediately get laptimes and all data needed for engine tuning as well as for improving driving technique.
Channel ExpansionIt permits to add 4 0-5Volt analog channels for pressure, temperature sensors and potentiometers. Two of these channels can be configured to receive digital inputs like wheel speed.
TC HubIt adds 4 K thermocouples.
LCU-One CANWide band Lambda controller LCU-One, with Bosch LSU 4.9 probe, providing all Air/Fuel data and lambda value, allows to perfectly tune the carburetion.
SmartyCam 3 camerasThe on-board cameras that overlays on videos the data sampled by your logger.
Memory ModuleThe Memory Module is a small SD Card holder that can be connected via CAN bus to your AiM logger in order to record the data during your tests.
These are only some of the items that can be added to our MXT 1.3 for incrementing the performance and the data acquired:
With Race Studio 3 you can also analyse all data recorded by MXP 1.3 Strada and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
- Display: 10" TFT
- Contrast: 1,100:1
- Brightness: 800cd/m
- Ambient Light Sensor: Yes
- Alarm LEDs: 6 configurable RGB LEDs
- CAN Connections: 3
- Analogue Inputs: 8 fully configurable, max 500 Hz each
- Digital Inputs: 4-speed input, lap signal, coil RPM input
- Digital Outputs: 2 (1 A max)
- Second CAN: Yes
- Internal memory: 4GB
- Body: Anodized Aluminium
- Connectors: 2 Autosport connectors + 1 Binder connector
- Power Consumption: 450 mA
- Dimensions: 278 X 135 X 43.2mm
- Weight: 1,200g
- MXT 1.3
- GPS Module with cable
- USB Cable
- 37 Pin Standard harness
The MXT 1.3 features a 10" wide colour dash display offering great visual impact, and configurable to show data coming from your vehicles ECU.Key Features :
The MXT 1.3 has an integrated shift array, configurable multicolor alarms, drag and drop multi page configuration, Wi-Fi and USB connectivity, GPS09 Module, analog and digital inputs, digital outputs, Motorsport connectors, 4 GB of internal memory, 1,000Hz per channel sampling and support for over 1,000 ECU connections.MXT 1.3 samples data coming from your ECU, the GPS09 Module, 8 fully configurable analog inputs, 6 digital inputs, predefined math channels and second CAN. Performance and data acquired can also be incremented adding up to eight expansion modules.
You can define up to 8 custom pages, choosing among a selection of page styles, defining which data to be shown, their end of scale and measure units. Swapping between pages can be managed pushing one or two pushbuttons.Display
A high contrast TFT display identifies MXT 1.3 at the first glance. An ambient light sensor keeps the backlight at optimum brightness levels.Flexible alarms & custom street icons
MXT 1.3 features five configurable RGB alarm LEDs: you choose the conditions, you choose the colors. Select a solid alarm or flashing one - and the flashing frequency, choose to have an accompanying text message, and set the alarm priorities. Furthermore you can select the street icons you need among the wide list you will find in "Race Studio 3 - Icons Management" and set them up the way you prefer or according with your needs. Any of them is fully configurable and if this shouldn't be enough, you will be able to upload and set up your own customized icons.Two digital outputs
MXT 1.3 features two digital outputs. The two digital outputs (Dout) are LOW SIDE type (switch to ground): they can be configured in order to be turned on/off depending on the value of the analog or digital inputs. They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc. when a certain event happens.Camera inputs, also for mirror camera
Two analog camera inputs are available, to swap your display into a mirror camera, through pushbutton command or event management.Integrated shift light array
Choose from a host of advanced multicoloured RGB shift light patterns that can be customized as you like, and for each unique gear when required.Expand Your System
Using the built-in CAN bus, you can add expansion modules to the MXT 1.3 to increment the performance and the data acquired:GPS09 Module Thanks to GPS09 Module (included in the kit) and its Race Studio 3 software, you can immediately get laptimes and all data needed for engine tuning as well as for improving driving technique.
Channel Expansion It permits to add 4 0-5Volt analog channels for pressure, temperature sensors and potentiometers. Two of these channels can be configured to receive digital inputs like wheel speed.
TC Hub It adds 4 K thermocouples.
LCU-One CAN Wide band Lambda controller LCU-One, with Bosch LSU 4.9 probe, providing all Air/Fuel data and lambda value, allows to perfectly tune the carburetion.
SmartyCam 3 cameras The on-board cameras that overlays on videos the data sampled by your logger.
Memory Module The Memory Module is a small SD Card holder that can be connected via CAN bus to your AiM logger in order to record the data during your tests.
These are only some of the items that can be added to our MXT 1.3 for incrementing the performance and the data acquired:Configure & Analyse with Race Studio 3
With Race Studio 3 you can also analyse all data recorded by MXP 1.3 Strada and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.Technical
- Display: 10" TFT
- Contrast: 1,100:1
- Second CAN: Yes
- Weight: 1,200g
- MXT 1.3
- USB Cable
