Aim MXS 1.3 TFT Car Dash Display Logger
SKU: MXS-CR4-XA2MXS12A40R1
- 정가
- £2,050.00
- 정가
- 세일 가격
- £2,050.00
- 단가
- 당
A Compact Colour TFT Digital Display For Motorsports
The MXS 1.3 Dash Logger has a 5" TFT digital display which has been designed to acquire and display data coming from the ECU. Its fully configurable display and compact size make it an ideal choice for racers who want valuable data at their fingertips, but might be limited by space in the cockpit.
Note: MXS Strada & Strada Light options are also available with road icons to suit a variety of vehicle applications.
MXS 1.3 Key Features
Why Choose The MXS 1.3 Car Dash Display & Data Logger
The Aim MXS 1.3 is a compact, but powerful motorsport display and data logger. It offers real time data on its 5” TFT screen, has customisable display layouts, lap timing capabilities thanks to the GPS09 Module (included in the kit) and is compatible with a range of Aim devices and expansions for the ultimate setup.
A Range Of Data Sources
The MXS is designed to collect and display data from the ECU, the internal accelerometer & gyro, the included GPS09 Module, analogue & digital inputs, and predefined math channels. You can also expand its capabilities by adding up to 8 modules to enhance performance and data acquisition.
Connecting the MXS 1.3 Dash to the ECU is simple. You can sample dozens of channels straight from the car's ECU, requiring only a cable connection to the ECU instead of multiple connections and analogue sensors.
The data you can sample will depend on your specific ECU, but it typically includes RPM, engine load, throttle position (TPS), oil, air & water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel ratio). The list of supported ECU drivers is regularly updated and now includes over 1,000 different ECUs.
Advanced Display
With its high-contrast 5” TFT display you can configure pages to suit your needs, choosing from a variety of styles, data types and measurement units. The digital display also allows you to easily navigate through the pages, which can be managed via one or two push buttons. An ambient light sensor adjusts the backlight for optimal brightness, ensuring clear visibility in all lighting conditions.
The system also supports 2 analogue camera inputs for a mirror camera function, activated by a push button or event. Note: The camera is sold separately.
Integrated Shift Light Array & LEDs
The MXS Display also comes with 6 RGB LEDs, allowing you to customise colours, alarm types (solid or flashing), flashing frequency and accompanying text messages. Alarm priorities can be set to suit your specific requirements.
2 Digital Outputs
The MXS 1.3 features 2 digital outputs, each capable of providing 1 amp at 12 volts. These outputs can be configured to turn on or off depending on the value of the analogue or digital inputs. This functionality allows you to automatically control external systems, such as switching additional lights on or off or activating and deactivating cooling fans or circulation pumps when specific events happen.
CAN Output
With the CAN output, you can send messages directly to an existing CAN network to improve the range of vehicle control possibilities.
GPS Module
The GPS Module, connected to the MXS via CAN, simplifies lap time calculation and track position analysis. With over 4,000 tracks worldwide already stored, including the start and finish line coordinates, you’ll have no trouble monitoring your position and lap times when you’re on the track.
Once the MXS is powered on, the GPS Module will quickly locate its position, identify the track’s coordinates and start recording lap and split times immediately. If the track isn’t in the database, you can easily add the start/finish line coordinates using the free Race Studio 3 software on your PC before heading to the track.
Note: The included GPS Module is available with 0.50m, 1.3m, 2m or 4m length cables. We also have an option for a roof-mounted version which is available with 2m or 4m length cables.
Pin Wiring Harnesses
The 37 Pin Wiring Harness comes standard in the kit, but you can also add an Aim 22 Pin Wiring Harness as an optional extra if you require more data.
Wi-Fi Connectivity
The MXS 1.3 Dash has integrated Wi-Fi to allow you to conveniently transfer your data securely, straight from your vehicle to your laptop/PC trackside. You can then review your racing data in more depth by importing it to our free Race Studio 3 software, which can be done from up to 50m away without the need for connectors and cables.
Compatible Expansions
The MXS Display is compatible with various expansions and modules to enhance performance and expand on data collection. Using the built-in CAN bus, you can add the following expansion modules to the MXS Displays setup:
With Race Studio 3, you can create, modify, delete, import, and export configurations for all channels, ECU drivers, math channels, display pages, digital outputs, alarms, shift lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps by watching the video recorded by SmartyCam HD cameras.
Race Studio 3 also allows you to download and analyse all data recorded by the MXS 1.3 Display. With graphs, histograms and tables, you can study your lap and sector times to refine racing lines and braking points to enhance your racing performance.
Advanced Display
2 Digital Outputs
CAN Output
GPS Module
Wi-Fi Connectivity
- Display: 5" Display
- Contrast: 600:1
- Ambient Light Sensor: Yes
- CAN connections: 3
- ECU connections: CAN, RS232 or K-LIne
- ECU compatibility: +1,000 industry leading ECUs
- Second CAN: Yes
- Internal Memory: 4 GB
- Body: Anodized Aluminium
- Power Consumption: 400mA
- Dimensions: 169.4 X 97 X 23mm
- Weight: 530g
What's In The Box
- MXS 1.3 Dash Logger
- 37 Pin Standard Harness
- GPS Module with Cable
- USB Cable
- Aim Sticker
