제품 정보로 건너뛰기
1 2
Aim MXK10 Kawasaki Ninja ZX-10R (Gen 5 2016-2020) Plug & Play Dash Logger
SKU: MXK10
정가
£995.00
정가
세일 가격
£995.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
Plug & Play Dash For Kawasaki ZX-10R
Upgrade your Kawasaki Ninja ZX-10R Gen 5 (2016-2020) with the Aim MXK10 Dash Logger — a high-performance Plug & Play Dash Logger designed for professional and track-day riders.
With a 5" high-contrast TFT display, customisable LEDs and seamless integration with your bike’s ECU, the MXK10 Kawasaki dash provides precise performance insights at a glance.
5" TFT Display 4GB Memory
GPS Module Included Comprehensive Data Logging
10 Shift Light LEDs 6 Status RGB LEDs
Wi-Fi Connectivity Plug & Play Connection
MXK10 Kawasaki Ninja ZX-10R Gen 5 Dash Logger
Why Choose The MXK10 Gen 5 Kawasaki Dash?
The MXK10 Dash Logger is more than just a display — it’s a professional-level data acquisition system with advanced features that provides riders with the tools to fine-tune performance, optimise lap times and enhance riding efficiency.
Please Note: The MXK10 dash can be programmed with your current mileage. Please state your required mileage in miles or kilometres in the notes section on your order.
Advanced Display & LED System
The MXK10 Kawasaki Dash features a high-contrast, customisable 5” TFT display, ensuring riders can clearly see important data in any lighting condition.
Enhancing functionality further, the dash includes:
  • 10 customisable shift light LEDs for optimal gear changes.
  • 6 RGB status LEDs alerts for engine performance, pressure, temperature and more.
Lap Timing & Data Logging
Equipped with a 25 Hz GPS09 module, the MXK10 Kawasaki Dash provides millisecond-accurate lap timing, automatic track recognition and track mapping capabilities. Once the bike is switched on near a known track, the GPS module automatically loads the start/finish coordinates, calculating lap times with precision. Note: If a track is missing, it can be created and added via Race Studio 3.
The MXK10 offers 2 riding modes:
  • Track Mode – Disables the lap pushbutton to avoid confusion between GPS signal and lap button.
  • Road Mode – Keeps the lap button enabled while disabling the GPS Module.
The 4GB onboard memory allows for over 3,000 hours of data storage, enabling riders to log, review and optimise their braking points, acceleration, throttle response and sector times. With ECU connectivity, the MXK10 dash records essential data, providing real time feedback to help improve riding efficiency and highlight potential faults.
The MXK10 Kawasaki Dash is compatible with various expansions and modules to enhance performance and expand on data collection. Some of the compatible expansions include:
Race Studio 3 also allows you to download and analyse all data recorded by your MXK10 Kawasaki Dash. With graphs, histograms and tables, you can study your lap and sector times to refine racing lines and braking points to enhance your racing performance.
  • Display: 5" TFT
  • Resolution: 800x480 pixels
  • Contrast: 600:1
  • Ambient Light Sensor: Yes
  • Status information LEDs: 6
  • Shift Lights LEDs: 10
  • CAN connections: 2
  • ECU connection: Yes
  • External Modules: GPS Module, Channel Expansion, Lambda Controller, SmartyCam HD
  • Wi-Fi connection: Yes
  • Internal memory: 4 GB
  • Body: 1 JAE connector & 2 Binder connectors
  • Dimensions: 166 x 97 x 23mm
  • Weight: 530g
  • Power consumption: 400 mA
  • MXK10-GEN 5 Dash Logger
  • Screws & Washers
  • GPS Module "Roof Version"
  • Anodised plate fixing kit & screws
