AiM Motocross Honda Solo 2 DL Plug & Play Lead
SKU: HON-MX-PP
- 정가
- £67.00
- 정가
- 세일 가격
- £67.00
- 단가
- 당
The AiM ECU plug & play cable has been specifically designed for Honda bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Honda plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL |
Honda Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Honda bikes. This plug & play cable can be used for the Solo 2 DL.
Honda CRF 250 cc - From 2010 onwards | Honda CRF 450 cc - From 2009 onwards |
Example data protocols
- Below is a pinout drawing for the Honda Solo 2 DL plug & play connection cable
- Honda Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Honda bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Honda bikes. This plug & play cable can be used for the Solo 2 DL.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Honda bike models:Honda CRF 250 cc - From 2010 onwards | Honda CRF 450 cc - From 2009 onwards |
Example data protocols sampled include RPM, Throttle position, Lambda value, Air temperature, Engaged gear, Battery supply Map switch and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list.Expand Your System
