제품 정보로 건너뛰기
1 4
AiM Brake Pressure Sensor M10 0-100 Bar Motocross
SKU: S-P-B-M10-X05PSA00100B10-MX
정가
£190.00
정가
세일 가격
£190.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
The AiM M10 0-100 Bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 100 bars. This sensor will monitor brake pressure levels for optimum performance accurately.
M10 -  0-100 Bar 4 pins 719 male binder
The AiM M10 - 0-100 Bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.
  • Supply: 8-16V
  • Consumption: < 10 mA
  • Sealing: IP66
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: M10
  • AiM Brake Pressure Sensor M10 - 0-10 Bar
  • Supply: 8-16V
  • Sealing: IP66
  • Weight: 30g
  • Thread: M10
