제품 정보로 건너뛰기
1 2
AiM 719 (Plastic) Binder Plug Male
SKU: P-719-M
정가
£10.00
정가
세일 가격
£10.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
The AiM 719 binder plug 4 pin male is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your AiM system.
Suitable for AiM sensors 4 pin male plastic Binder
Ideal for adding to your system
The AiM 719 binder plug 4 pin male is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your AiM system. The plug has four pins.
Ideal for replacing broken plugs or when adding sensors to your AiM system
Fits AiM 719 cables and sensors
  • 719 Plastic Binder Plug
  • 1 x 719 Plastic Binder Plug
