제품 정보로 건너뛰기
1 2
AiM 6" TFT Dash Display with Road Icons for PDM08/PDM32
SKU: DISPLAY-6-I-XC1D06000
정가
£335.00
정가
세일 가격
£335.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
The AiM 6" TFT dash display with road icons is suitable as a replacement unit for those supplied with the AiM PDM kits or an upgrade for PDM kits that do not include a dash display.
6" TFT dash display Road Icons
Five status information LEDs  Ten shift light LEDs
Fully configurable display Range of layouts
6" TFT Dash Display
Check out the Downloads Tab for all the information required on connection and programming to the PDM08 and the PDM32.
Please note - the 6" dash display is ONLY for use with AiM PDM kits and can not be used as a stand-alone dash display.
Optional Extra
The dashes also double up as a reversing mirror using a separately available camera—ideal for cars with limited rear vision. You can add up to 2 cameras for both front and rear views. You can find the optional Reversing Mirror Camera in the Accessories Tab. You will require a PDM32 in order for this to work.
Improve your performance
Add extra devices to your system to give additional data and improve your racing performance, such as GPS Module, Channel Expansion, TC Hub, SmartyCam HD, Lambda Controller, Remote i/o Pushbutton Module, Formula Steering Wheel, TPMS System, and Keypads.
With Race Studio 3, you can also analyse all data recorded by MXL2 and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performance.
  • Display: 6: TFT
  • Contrast: 600:1
  • Ambient Light Sensor: Yes
  • Status information LEDs: 5
  • Shift Light LEDs: 10
  • Body: Anodized Aliminium
  • Pushbuttons: Metallic
  • Connectors: LVDS Link 4 Pins Rosenberger male connector
  • Weight: 640g
  • Power consumption: 150 mA
  • 6" TFT Dash Display with Road Icons
6" TFT Dash Display
Optional Extra
  • Display: 6: TFT
  • Contrast: 600:1
  • Weight: 640g
