제품 정보로 건너뛰기
1 3
AiM 37 Pin Deutsch Harness with 1 Thermocouple MXS, MXP, MXG, MXL2, MXm Motorcycle
SKU: H37-ST-V02573040-MC
정가
£375.00
정가
세일 가격
£375.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
The AiM 37 pin Deutsch Harness with one thermocouple connector to connect a K-Line type sensor.
Suitable for MXS, MXP, MXG, MXL2. MXm Digital output
 37 pin harness One thermocouple connector
 37 pin Harness with One Thermocouple Connector for the MX Series
The AiM 37 pins harness has been designed with one thermocouple connector, this will enable you to connect a thermocouple sensor to your device.
Digital wheel speed channel 1
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
Also available is a 37 pins Deutsch harness with two thermocouple connectors, available in the Accessories Tab.
  • Female Thermocouple Connector - See table in Downloads Tab
  • 37 pin Deutsch Harness
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
