제품 정보로 건너뛰기
1 1
AiM 14 Pin Strada 1.2 OBDII Harness for MXS, MXP, MXG Motorcycle
SKU: MX-S-L-OBDII-V02573340
정가
£160.00
정가
세일 가격
£160.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
AiM 14 Pin Strada 1.2 OBDII Loom for MXS, MXP, MXG Motorcycle
The AiM 14 pin connector harness is a standard replacement for the Strada MXS, MXP, MXG (MX series) dash displays.
Fits MXS, MXG, MXG dashes Replacement for original wiring
 14 pin AMP female connector 4 pin binder 719 female
 5 pin binder 712 female 16 pin OBDII
14 Pin AMP OBDII Harness
The AiM 14 pin Strada 1.2 AMP connector with OBD11 connector is a standard replacement for the MXS, MXG, MXP (MX Series) dash displays.
With pre-wired connectors for easy connectivity. A 14 pin AMP female connector, 4 pins Binder with 719 female connectors, 5 pins Binder 712 female connector and 3 cables.
  • 14 pins AMP female flying connector
  • 4 pins Binder 719 female connector
  • 5 pins Binder 712 female connector
  • 16 pins ODB11 flying connector
  • x3 1 x 0.5 cables
  • 14 pin Strada 1.2 OBDII Harness
  • x3 1 x 0.5 cables
