Yamaha YZF- R1 & YZF-R6 AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: YAM-2-B
- 通常価格
- £60.00
- 通常価格
- セールスプライス
- £60.00
- 単価
- あたり
The AiM Yamaha motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Yamaha bracket | All necessary mounting hardware |
Suitable for Solo 2 & Solo 2 DL | |
Yamaha Solo 2 & Solo 2 DL Bracket
The Yamaha YZF-R1 & YZF-R6 bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Note: If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Also available is our Yamaha plug & play cable for the following bike models: (Sold Separately)
Yamaha YZF-R1 (YEC included) - 2004-2014 | Yamaha YZF-R6 (YEC included) - 2004-2016 |
Yamaha YZF-R1 (YEC included) - 2009-2014 | Yamaha YZF-R6 (YEC included) - 2004-2005 |
Example data protocols
- Specifically designed Yamaha YZF-R1 & YZF-R6 bracket for the Solo 2 and Solo 2 DL
- 1 Bracket
- 2 spacers
- 2 self-locking nuts M6
- 4 washers M6
- 2 self-locking nuts M4
- 2 washers M4
- 2 Allen screws with rounded head M6 x 60mm
The AiM Yamaha motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
The Yamaha YZF-R1 & YZF-R6 bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.Our brackets are supplied with all the necessary hardware required for fitting to your bike.
Also available is our Yamaha plug & play cable for the following bike models: (Sold Separately)Yamaha YZF-R1 (YEC included) - 2004-2014 | Yamaha YZF-R6 (YEC included) - 2004-2016 |
- 1 Bracket
- 2 spacers
- 4 washers M6
- 2 washers M4
- 選択を選択すると、ページ全体が更新されます。
