製品情報にスキップ
1 5
Yamaha Plug & Play AiM Taipan Y Motocross ECU Kit
SKU: C-ECU-YAM-250F-19
通常価格
£635.00
通常価格
セールスプライス
£635.00
注文すべてでカーボンニュートラルな配送
AiM Taipan Y ECU Plug & Play Kit For Yamaha Motocross Bikes
Taipan Y is the brand-new aftermarket plug & play ECU created by AiM, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.
Taipan Y Key Features & Advanced Strategies
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Taipan Y ECU guarantees a precision of 1/10 of degree: this means an accuracy within 0.8 usec for turning the spark ON!
Advanced Base Maps For Your Yamaha
Aim Taipan Y ECU includes a base map that immediately offers improved performance over the OEM control units.
Taipan Y ECU currently fits the following Yamaha motocross bikes :
UC Bridge
User License : A Taipan Y ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
- Receiving diagnostic information from the Taipan Y ECU.
Tuner License :
Taipan Y ECU Connections
The Taipan Y ECU has 4 connectors :
Aim Handlebar Switch
Below shows a functional diagram of products that can be added to the Taipan Y ECU:
AiM Taipan Y ECU Plug & Play Kit for Yamaha
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • Plug & Play ECU for Yamaha
Traction Control
Launch Control
UC Bridge
Tuner License :
  • Waterproof: IP67
  • Weight: 260g
Video
