製品情報にスキップ
1 4
Triumph Daytona, Street Triple & Speed Triple AiM Solo 2 DL Plug & Play Cable
SKU: SOLO-K2-L
通常価格
£42.00
通常価格
セールスプライス
£42.00
注文すべてでカーボンニュートラルな配送
The AiM ECU plug & play cable has been specifically designed for Triumph bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Triumph plug & play cable 7 pin - 712 male binder connection
Triumph Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Triumph bike. This plug & play cable can be used for the Solo 2 DL.
The plug & play cable currently fits the following Triumph bike models:
Daytona 675 - 2006-2012 Street Triple - 2007-2012
Speed Triple - 2007-2012
Example data protocols
  • Below is a pinout drawing for the Triumph Solo 2 DL plug & play connection cable
  • Triumph Daytona, Street Triple, Speed Triple Plug & Play connection cable
