製品情報にスキップ
1 5
MV Agusta F3 & F4 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SM-CAM-GP-2-SOLO2-K-MV-SM-GPC
通常価格
£2,210.00
通常価格
セールスプライス
£2,210.00
注文すべてでカーボンニュートラルな配送
MV Agusta F3 & F4 AiM Solo 2 DL + SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
The MV Agusta plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide MV Agusta ECU connection cable
MV Agusta F3
This ultimate track day kit has been specifically designed for MV Agusta bikes. The kit includes a plug & play interface cable for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your MV Agusta ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
The plug & play cable currently fits the following MV Agusta bike models:
F3 675 - From 2012 F3 800 - From 2012
F4 1000 - From 2013
Powerful Combination
The MV Agusta ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
SmartyCam 3 GP
Automatic Start/Stop
MV Agusta F3
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 VoltSupports SD card: Up to 2 TB
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65
Below is the pinout drawing for the MV Agusta plug & Play connection cable.
MV Agusta F3 & F4 AiM Solo 2 DL + SmartyCam 3 GPMotorcycle Plug & Play Lap Timer Track Day Kit
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • MV Agusta Plug & Play connection cable
MV Agusta F3
F4 1000 - From 2013
SmartyCam 3 GP
MV Agusta F3
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
