Link Toyota SupraLink - TS2JZX PlugIn ECU
SKU: TS2JZX-211-4000
- 通常価格
- £1,325.00
- 通常価格
- セールスプライス
- £1,325.00
- 単価
- あたり
Designed for the 2JZ non VVTi engine.
No onboard MAP sensor.
XS Loom & map sensor highly recommended.
Suitable Applications:
Toyota Supra 2JZ non VVTi
This ECU will support naturally aspirated, parallel twin or single turbo configurations. Does not support sequential control of the stock twin turbos (note: does not fit the case of the NA supra)
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
The Toyota Supra plug-in ECU has two expansion connectors.
From PCB revision 1.2:
Expansion Connector 1:
Gnd Sensor Ground Only
An Volt 7 Analog 0-5V input
An Volt 6 Analog 0-5V input
DI 8 Digital input
DI 7 Digital input
Expansion Connector 2
Aux 9 EThrottle - can't be used as an Aux Out
DI 9 Digital input
DI 10 Digital input
An Volt 8 Analog 0-5V input
An Volt 9 Analog 0-5V input
An Volt 10 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
Toyota Supra 2JZ non VVTiThis ECU will support naturally aspirated, parallel twin or single turbo configurations. Does not support sequential control of the stock twin turbos (note: does not fit the case of the NA supra)
CAN port
Staged injection
The Toyota Supra plug-in ECU has two expansion connectors.From PCB revision 1.2:
DI 8 Digital input
DI 7 Digital input
DI 9 Digital input
DI 10 Digital input
- G4X PlugIn ECU
- Stickers
- 選択を選択すると、ページ全体が更新されます。
