Link Nissan 300Link - #N300X PlugIn ECU
SKU: N300X
- 通常価格
- £1,195.00
- 通常価格
- セールスプライス
- £1,195.00
- 単価
- あたり
The N300X ECU is Designed to suit the VG30DET engine.
Includes an onboard 4 bar or 7 bar MAP sensor.
It is highly recommended to fit an IAT sensor with this model.
Suitable Applications:
Z32 300ZX VG30DE
Z32 300ZX VG30DETT
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
DI 5 Digital Input
DI 6 Digital Input
Volt 8 Analog Volt Input
Volt 7 Analog Volt Input
Temp 3 Analog Temp Input
Temp 4 Analog Temp Input
Expansion connector 2
Gnd Sensor Ground Only
DI 7 Digital Input
DI 8 Digital Input
An Volt 9 Analog 0-5V input
An Volt 10 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
Z32 300ZX VG30DEZ32 300ZX VG30DETT
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI 5 Digital Input
DI 6 Digital Input
DI 7 Digital Input
DI 8 Digital Input
- G4X PlugIn ECU
- Stickers
- 選択を選択すると、ページ全体が更新されます。
