Link Crank Angle Sensor (CAS)
SKU: CAS
- 通常価格
- £115.00
- 通常価格
- セールスプライス
- £115.00
- 単価
- あたり
+ VAT(英国のみ)
Used in conjunction with a trigger wheel to measure the crank angle, a vital measurement for engine operation. Can be used with almost any steel trigger wheel, see related products for our trigger wheel options.
Variable reluctance (reluctor) sensor
Includes Plug Kit - 2 way Bosch Style plug, terminals and boot
- Crank Angle Sensor
- Plug Kit - 2 way Bosch Style plug, terminals and boot
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Link_Banner_Description.png?v=1616071775)
Used in conjunction with a trigger wheel to measure the crank angle, a vital measurement for engine operation. Can be used with almost any steel trigger wheel, see related products for our trigger wheel options.Variable reluctance (reluctor) sensor
![Link Crank Angle Sensor (CAS) - AimShop.com](http://www.aimshop.com/cdn/shop/products/LinkCrankAngleSensor_CAS_1445x.png?v=1618228046)
![Link Crank Angle Sensor (CAS) - AimShop.com](http://www.aimshop.com/cdn/shop/products/LinkCrankAngleSensor_CAS_2_1445x.png?v=1618228049)
![Link Crank Angle Sensor (CAS) - AimShop.com](http://www.aimshop.com/cdn/shop/products/LinkCrankAngleSensor_CAS_3_1445x.png?v=1618228052)
- 選択を選択すると、ページ全体が更新されます。
