Ducati Panigale V4/V2 AiM Solo 2 DL Plug & Play Cable
SKU: DUC-PP
- 通常価格
- £67.00
- 通常価格
- セールスプライス
- £67.00
- 単価
- あたり
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale V4/V2 bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Ducati Panigale V4/V2 plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL |
Ducati Panigale V4/V2 Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale V4/V2 bike. This plug & play cable can be used for the Solo 2 DL.
The plug & play cable currently fits the following Ducati Panigale bike models:
Panigale V4 - From 2018 | Panigale V2 - From 2020 |
Example data protocols
- Below is a pinout drawing for the Ducati Panigale V4/V2 plug & play connection cable
- Ducati Panigale V4/V2 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale V4/V2 bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale V4/V2 bike. This plug & play cable can be used for the Solo 2 DL.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Ducati Panigale bike models:Panigale V4 - From 2018 | Panigale V2 - From 2020 |
- 選択を選択すると、ページ全体が更新されます。
