Ducati Panigale AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: DUC-1-B
- 通常価格
- £60.00
- 通常価格
- セールスプライス
- £60.00
- 単価
- あたり
The AiM Ducati Panigale motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Ducati Panigale bracket | All necessary mounting hardware |
Suitable for Solo 2 & Solo 2 DL | |
Ducati Panigale Solo 2 & Solo 2 DL Bracket
The Ducati Panigale bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Note: If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Also available is our Ducati Panigale plug & play cable for the following bike models: (Sold Separately)
899 Panigale - 2013-2015 | 959 Panigale - From 2016 |
1199 Panigale - 2012-2014 | 1199R Panigale - 2015-2017 |
1299 Panigale - 2015-2019 | Panigale V4 - From 2018 |
Panigale V2 - From 2020 |
Example data protocols
- Specifically designed Ducati Panigale 899, 959, 1199, 1199R, 1299, V4, V2 bracket for the Solo 2 and Solo 2 DL
- 1 Bracket
- 1 washer
- 1 rubber dowel
The AiM Ducati Panigale motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
The Ducati Panigale bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.Our brackets are supplied with all the necessary hardware required for fitting to your bike.
Also available is our Ducati Panigale plug & play cable for the following bike models: (Sold Separately)899 Panigale - 2013-2015 | 959 Panigale - From 2016 |
- 1 Bracket
- 1 washer
- 1 rubber dowel
- 選択を選択すると、ページ全体が更新されます。
