製品情報にスキップ
1 8
Ducati Panigale V4/V2 Euro5 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-DUC-EURO5
通常価格
£710.00
通常価格
セールスプライス
£710.00
注文すべてでカーボンニュートラルな配送
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Ducati this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Ducati Panigale ECU connection cable
This kit has been specifically designed for Ducati Panigale bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Ducati Panigale ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Ducati Panigale bike models:
Panigale Euro5 V4 - From 2018 Panigale Euro5 V2 - From 2020
The Ducati Panigale ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Ducati Panigale V4/V2 plug & play connection cable.
Ducati Panigale V4/V2 AiM Solo 2 DL Plug & Play Lap Timer Kit
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Ducati Panigale V4/V2 Connection Cable
  • Bracket
  • 1 washer
  • 1 rubber dowel
