BMW S1000RR AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: BMW-PP-BMW-B
- 通常価格
- £120.00
- 通常価格
- セールスプライス
- £120.00
- 単価
- あたり
The AiM BMW motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
BMW cable & bracket | 7 pin - 712 male binder connection |
BMW Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the BMW bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM BMW bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following BMW bike models:
S1000RR - 2009-2014 | S1000RR - From 2015 |
S1000RR HP4 - 2013-2014 |
Example data protocols
- Specifically designed BMW S1000RR Plug & play cable and bracket for the Solo 2 DL
- Below is the pinout drawing for the BMW plug & play connection cable.
- BMW plug & play connection cable
- 1 bracket
- 1 toothed washer
- 1 rubber dowel
- 1 spacer
The AiM BMW motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.Key Features :
The AiM ECU plug & play cable has been specifically designed for the BMW bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.The AiM BMW bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following BMW bike models:S1000RR - 2009-2014 | S1000RR - From 2015 |
- 1 bracket
- 1 toothed washer
- 1 rubber dowel
- 1 spacer
- 選択を選択すると、ページ全体が更新されます。
